The Old Farts Guide to the PTC Community - Setting Up Streams, Following Communities, & Filterin
davehaigh
After you have an account set up, Pick on the PTC Community title to go to the Welcome page.
It was brought to my attention that all the pictures got stripped out and you have to go to the PTCUser to download them. Attached is a pdf. I'm sure it will get stripped out also, but at least you can go download the pdf.
David Haigh
Thank you David!
From one 'Old Fart' to another, I appreciate the tips.
Steve
I just realized I made a mistake.
I said, "From the welcome page you want to set up some "Streams" The names you give these will show up in the emails you receive."
Turns out that's not true. Those names are not set by what you name the stream. They are hard coded by the web site.
I realized this after I stated following the modeling community. I started getting emails in my in-box with this in the subject line:
