Need to perform some administering tasks and data altering on productive Windchill environment (but not cluster) that can take a few days.
The users should be prevented to alter the system in this time.
What is the recommended way to prevent login or to set the system on read-only for all the users except admin.
Filter user access by IP address
Filter user access by username
My preferred method is by username. But it is up to you, of course.
