The easiest way to copy text from any table
berny2U
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.2
Is there any way to easily copy/paste text from any displayed table to the Windows clipboard. We have a promotion approver that handles houndreds of numbers a day. The click/drag/Ctrl+C option is just not handy enough.
8 REPLIES 8
berny,
Can you describe your use case?
The promoter copies the highlighted row and then what? Where is he pasting the text? In side or outside of Windchill?
David
berny2U
(To:d_graham)
David
The promotor is selecting the document number and pushes CTRL+C then paste this info in another application.
I was hoping there is a way a button (a single click) could copy that info.
He is a heavy Windchill user and each click saved could make a huge difference.
rleir
(To:berny2U)
It sounds as if you could use a QueryBuilder report. Choose the fields you want, set the desired format, export to xlsx
berny2U
(To:rleir)
Hi rleir
I will keep this as an option. The need for copy/paste is due some bug in the Creo viewer during printing.
If the printing problem is solved this need will disapear.
Thanks anyway for the suggestion.
berny2U
(To:Marco_Tosin)
Hi Marco
I will take a look to these, thanks.
another option is to look for a browser extension to handle tables. i had a really good one with IE for Windchill 11.1 but have not had to find a replacement now that we're using chrome on Windchill 12.0. check out the extension store for your favorite browser and i'm sure you'll find something that might do the trick..
