I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.4
There is no out-of-date prompt for the target component and drawing in the workspace, but an out-of-date prompt appears after opening the drawing
Translated text from Simplified Chinese to English using google translate
Subject - 在工作区的状态图标不起作用了
Body - 在工作区内目标组件和图纸没有出现过时提示,但是打开图纸后出现过时提示
- By Community Moderation Team
Article - "Windchill PDMLink 11.0: "Visualization Data Out Of Date" popup window will not be triggered before opening an outdated representation": https://www.ptc.com/en/support/article/CS258127
Is this the message you are seeing? "WARNING: This drawing is more recent than the model"
Thanks for your help.
Commonly, we can see the iron in integration view.
But now it just appeared at Creo
If you customize the Workspace view, you can add the column for "Out of Date" objects. Then you should see a clock icon for the items in the Workspace that are not the latest iteration.
