I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS16
CAD Part - 254440227_.prt, A.1 could not be deleted/purged. There are objects associated to it through EPMBuildHistory link.
Here are the errors that I faced
Take a look at this article
I found it by doing a search in the Technical Support Knowledge Base with the error you reported.
