To integrate Cadence 22.1 version of system capture, which version of Windchill can support integration?
石匪_999308111111
2-Explorer
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.3
I want to integrate Cadence 22.1 version of system capture. Which version of Windchill can support integration? 12.1? 13.0? Can they all be supported?
Translated the topic from Simplified Chinese to English using google translate
Subject: 要针对Cadence 22.1版本的system capture做集成,请问哪个版本的Windchill能支持集
Body: 要针对Cadence 22.1版本的system capture做集成,请问哪个版本的Windchill能支持集成?12.1?13.0?是否都能支持?
- By Community Moderation Team
Article - "How to create integration between Cadence/Mentor ECAD Library and Library in Windchill PDMLink 10": https://www.ptc.com/en/support/article/CS122656
Are you looking to integrate to manage the data or the libraries that support these tools? I believe PTC was not continuing support for WGM for ECAD and outsourcing it. Try here:
https://www.xplm.com/our-solutions/plm-integrations/ptc-windchill/#:~:text=The%20direct%20integration%20of%20ECAD,a%20common%20mechatronic%20PLM%20environment.
Since Windchill 11.2, all ECAD integrations are now partner-based (as @avillanueva already stated). Those partners are actually our partner XPLM and the major ECAD vendors, including Cadence. So I would suggest to reach out to your contact at Cadence for integration between System Capture and Windchill. Additional information about point of contacts is available from CS298492.
Ruediger
