Two attributes refer to same IBA definition
VasiliyRepecki
Hi.
I have a situation with two attributes referred to same IBA. To delete one of them it should be removed from layouts. But i have next error when i try to delete one of them from layout:
"Attributes *** and *** on ru.sniihim.DefaultEPMDocument refer to the same iba definition"
How can i solve this problem? Windchill verison 10.1
Thanks.
I belief this could be a bigger problem. Windchill doesn't allow it to create on the same type two different attributes refering to the same IBA.
Probably it's better to open up new Case at PTC to solve this problem.
Hi Vasiliy,
Perhaps using Calculated attributes would resolve this issue. (possible Workaround)
But I would suggest the same as Bjorn, that this might be best dealt with as a case.
Jarrett
