I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS10
While editing the part attribute the values get merged.
Hi @Nandha
Describe your case more widely.
What a softtype? What an attribute? what values? What types?
It is not clear what your needs or what is your issue.
PetrH
Hi
Type - part.
Attributes - XXXX (Example - Material), data type - String
Constrains - Legalvalue
Image for your reference.
Hi @Nandha
You need to check the type and attribute management definition of the enumerated list
There can be some wrong definition.
PetrH
It is defined as legal value list.
we used correct separator.
100+
is that possible to overcome the issue in legal value list.
is there any possibility to overcome the current issue with same constrain - Legal value list.
Hi @Nandha
I've never seen this situation. I would check the correct definition in the definition of the legal value list. Or I would say that there could be some limit.
PetrH
Hi
Can you check and correct type and attribute in subtype (document or part type) in organization or site utility with admin credential ,
check weather may be the attribute legal value or enumerate value then correct spacer ( | ) in between value
otherwise connect with me i help further
Thank
Sarathkumar M
Hi
I will check the Spacer once again and update.
Thank you for the response.
