Unable to access windchill due to Solr server error
KV_10407246
7-Bedrock
When login to windchill UI, page keeps loading and getting Solr server error in Method server logs.
Method Server Logs:
2025-05-20 18:24:37,751 ERROR [pool-5-thread-1] wt.index.StandardIndexPolicyManager  - Exception while pinging the index server org.apache.solr.client.solrj.impl.BaseHttpSolrClient$RemoteSolrException: Error from server at http://xxxxxxxxxxxxxxxxxx.com:8085/solr/wblib/admin/ping?wt=javabin&version=2: Expected mime type in [application/vnd.apache.solr.javabin, application/octet-stream] but got text/html. <html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=utf-8"/>
<title>Error 404 Not Found</title>
</head>
<body><h2>HTTP ERROR 404 Not Found</h2>
<table>
<tr><th>URI:</th><td>/solr/wblib/admin/ping</td></tr>
<tr><th>STATUS:</th><td>404</td></tr>
<tr><th>MESSAGE:</th><td>Not Found</td></tr>
<tr><th>SERVLET:</th><td>-</td></tr>
</table>
</body>
</html>
at org.apache.solr.client.solrj.impl.HttpSolrClientBase.checkContentType(HttpSolrClientBase.java:335)
at org.apache.solr.client.solrj.impl.HttpSolrClientBase.processErrorsAndResponse(HttpSolrClientBase.java:221)
at org.apache.solr.client.solrj.impl.Http2SolrClient.processErrorsAndResponse(Http2SolrClient.java:571)
at org.apache.solr.client.solrj.impl.Http2SolrClient.request(Http2SolrClient.java:527)
at org.apache.solr.client.solrj.SolrClient.request(SolrClient.java:1194)
at wt.index.service.SolrServiceImpl.pingSolr(SolrServiceImpl.java:144)
at wt.index.StandardIndexPolicyManager.updateIndexServerStatusCache(StandardIndexPolicyManager.java:509)
at wt.index.StandardIndexPolicyManager$IndexServerStatusManagerTask.run(StandardIndexPolicyManager.java:489)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
Looking for response.
Fadel
23-Emerald I
(To:KV_10407246)
The two (or three) are unrelated.
Your SSL certificate error is tied to your SSL certs in the Java keystore (jssecacerts) and Apache.
The hamster wheel can be something entirely separate.
Windchill will start and be usable even if SOLR is inaccessible.
SSL Certificate is not the issue. I can still access another similar Windchill server.
Hello @KV_10407246
It looks like you have some responses on your topic. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
