Unable to launch PSI for Windchill 13.0 on Windows 10
MattPat
just like in the title I am trying to install test server on VM and I am not able to launch PSI wizard for Windchill 13.0 and 12.1. When I run setup.vbs there is progress bar with some configuring info and then window is closed.
I have java:
java version "17.0.8" 2023-07-18 LTS
Java(TM) SE Runtime Environment (build 17.0.8+9-LTS-211)
Java HotSpot(TM) 64-Bit Server VM (build 17.0.8+9-LTS-211, mixed mode, sharing)
 and java in environments:
Thanks in advance.
TomU
(To:MattPat)
Have you seen this notification on the PTC homepage?
It leads to this article: https://www.ptc.com/en/support/article/CS398580
Try rolling back to an earlier build of Java.
7 REPLIES 7
BenLoosli
(To:MattPat)
Is Windchill 13.0 supported on Windows 10? Normally Windchill is installed on servers, like Windows Server 2019.
Are you running the PSI as administrator, Run As Administrator?
I tried to find a matrices for Windchill 13 compatibility but did not see one.
MattPat
(To:BenLoosli)
Yes, I tried to launch it also thru powershell with administrative priviliges but same issue. It's closing after the startup progress bar will hit 100%.
Same errors occurs on Windchill 12.1 PSI.
MattPat
(To:BenLoosli)
It is possible to install it on client Windows, I did it on 11.2 and Win 10 just for testing purpose and some preparations.
Here it is a release matrix:
Windchill PLM 13.0.0.1 Release Matrix - PTC Release Advisor
BenLoosli
(To:MattPat)
Client platform: PTC has tested and verified the product on Windows 10 Enterprise 21H2. Support for Windows 10 as a client platform for Windchill is deprecated.
TomU
(To:MattPat)
avillanueva
23-Emerald I
(To:TomU)
We might have a winner. Good pick up.
MattPat
(To:TomU)
thank you, it works!
