Unable to launch PTC Solution Installer for windchill 12.1.2.0
YR_11024860
Version: Windchill 12.1
Use Case: Unable to launch PTC Solution Installer for windchill 12.1.2.0
Description:
Description:
Hello, @YR_11024860
If you’re unable to launch the PTC Solution Installer for Windchill 12.1.2.0, here are a few steps you can try to resolve the issue:
Check System PATH: Ensure that your system PATH variable includes the path to your installed SDK bin directory.
Run as Administrator: Try running the installer as an administrator to ensure it has the necessary permissions.
Avoid Windchill Shell: Do not run the installer from a Windchill shell, as service pack updates may affect the Windchill command code.
Correct Setup File: Make sure you are running the correct setup.vbs file for the PTC Solution Installer.
Java Environment: Verify that your JAVA_HOME environment variable is set correctly and points to a compatible Java version.
I hope this step is helpful to you.
Best Regard,
diana658h
BenLoosli
(To:YR_11024860)
What OS are you installing 12.1.2.0 on?
Are you an administrator on that computer and in the administrator group?
Hello @YR_11024860,
It looks like you have some responses from some community members. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
