I understand, so check the article I've provided, you will understand the connections.
then you can check the database tables .
You could see some similar names with the information provided in the article.
Especially following tables in the database EPMDocument table and also EPMDocumentMaster, EPMDocumentMemberLink tables are interesting.
PetrH
Hello @Vignesh_AJ_77
The BOM of EPM Document is in the detail page in the structure Tab.
btw use the support knowledge base search
PetrH
Hi @HelesicPetr ,
Thanks for the response. But I need to locate this BOM info in the database tables of windchill. Not in the UI.
PetrH
Thank you. I will refer to the article to check which tables are connected and can be used for this purpose.
Hello @Vignesh_AJ_77,
It looks like you have some responses from a community member. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
