Unable to run xconfmanager ??
kc-2
6-Contributor
I tried to configure my windchill server for Email. but while try to run the xconfmanager i am getting the below errors,
  • ERROR [main] com.ptc.windchill.structconf.StructConfManager - Unexpected error (stack trace belo
    w):
    com.ptc.windchill.structconf.PropagationActionException: Invalid number of fields in additional adapter definition, encr
    ypted.
            at com.ptc.windchill.structconf.PropagationAction.newPropgationActionException(PropagationAction.java:183)
            at com.infoengine.ieinstall.MapCredentialsAction.addAdapters(MapCredentialsAction.java:108)
            at com.infoengine.ieinstall.MapCredentialsAction.evaluate(MapCredentialsAction.java:263)
            at com.ptc.windchill.structconf.TargetFileContentsCollector.evaluatePropagationActions(TargetFileContentsCollect
    or.java:530)
            at com.ptc.windchill.structconf.TargetFileContentsCollector.writeTargetFiles(TargetFileContentsCollector.java:45
    6)
            at com.ptc.windchill.structconf.StructConfManager.propagate(StructConfManager.java:197)
            at com.ptc.windchill.structconf.Propagate.execute(Propagate.java:57)
            at com.ptc.windchill.structconf.StructConfManagerCommand.execute(StructConfManagerCommand.java:102)
            at com.ptc.windchill.structconf.StructConfManager.execute(StructConfManager.java:259)
            at com.ptc.windchill.structconf.StructConfManager.execute(StructConfManager.java:273)
            at com.ptc.windchill.structconf.StructConfManager.main(StructConfManager.java:820)
Can anyone help me on this issue...
jmomber
(To:kc-2)
kc-2
6-Contributor
(To:jmomber)
Hi Jamie,
I have seen this article .but i did not used any ; for any of my passwords.
Is there any other properties to change??
jmomber
(To:kc-2)
Strange. The error message is exactly the same as in the case, so I would suspect it still has something to do with the encryption. How are you setting the password? Are you using: xconfmanager -s wt.mail.smtp.password=<Password> -t mail.properties -p or putting it in site.xconf and then running xconfmanager -p?
