Dear All,
Good Day To You...
I'm performing Windchill cloning process. As part of that, performed below activities on Source machine..
And performed below activities on target machine...
Now, while trying to start Windchill, Method Server is not getting started.
It gives following error...
Nested exception is: wt.services.ManagerException: Could not initialize Auditing service.
I'm here by attaching log file contains exceptions...
I kindly request you to help me out to overcome these problems for successful clone.
Thanks In Advance.....
Change in file "wt.properties" this properties-> java.rmi.server.hostname=hostenameXX.xx ---> java.rmi.server.hostname=plm.test.com
and execute this command shell :
xconfmanager -p
Pascal
Hi Mr. Pascal,
Thanks for your reply..
I've checked wt.properties and host name which is plm.test.com is already there for the property java.rmi.server.hostname.
Anyhow, I've given same host name and executed xconfmanager -p in Windchill shell.
But, I'm still getting same error.
I'm here by providing screen shots regarding wt.properties, Windchill shell.
Kindly request you to check them once...
See : https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS20673&lang=en
Pascal
Hi Mr. Pascal,
I've followed the instructions from the above article. But, still same error continues..
Are you following the clone procedure in the Windchill Rehost Guide? If not, try following the clone procedure in the guide, and perform the LDAP copy using the rehosting script:
http://support.ptc.com/WCMS/files/105438/en/WC91RehostGuide.pdf
