Unable to start queues?
jfrancis
I get the below popup when I try to start the queue
The logs  say
2016-09-20 07:16:25,842 INFO  [ajp-bio-8010-exec-6] wt.system.err wcadmin - *ERROR* Failed to  start  Queue(WfPropagationQueue), state STARTING timed out
2016-09-20 07:16:25,845 INFO  [ajp-bio-8010-exec-6] wt.system.err wcadmin - *ERROR* Failed to  start  Queue(WfPropagationQueue), db state is STARTING
2016-09-20 07:16:25,845 INFO  [ajp-bio-8010-exec-6] wt.system.err wcadmin -  Services defined on this node: MethodServer, executeQueues = false, cache master codebase null
2016-09-20 07:16:25,845 INFO  [ajp-bio-8010-exec-6] wt.system.err wcadmin -  Queue Group/executionhost: (default/null), enabled true
2016-09-20 07:16:25,845 INFO  [ajp-bio-8010-exec-6] wt.system.err wcadmin -  Inside a nested transaction? false
2016-09-20 07:16:25,856 INFO  [ajp-bio-8010-exec-6] wt.system.err wcadmin -  Server (info) type wt.method.MethodServerInfo@5fa81d2e
bkontham
(To:jfrancis)
Below support article might help you to identify the root cause.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS39337
hs-2
6-Contributor
(To:jfrancis)
  • Enable queue execution in one MethodServer
  • In a single Method Server installation set wt.queue.executeQueues=true in wt.properties
Hi
Sometime the queues are configured to run in the background server or in a dedicated method server. So if this Server is not running the Queues won't start.
Check that your configuration is correct and all you MS servers are up an running ...
