Hello All,
"Update Distribution Target" action is disable for user How we can enable it?
@HelesicPetr
Can you enable jcaDebug and share a screenshot
Hi @AP_10750193
What Windchill version do you use?
I guess that there can be some license issue that user is not member of the right license group.
PetrH
Hello @HelesicPetr ,
I am using 12.1
And please find below image I can able to see it using admin access.
@Fadel FYI
Hi @AP_10750193
Sure, the admin can be part of a group that has an access. Or has an access based on admin group that has full control ACL settings
Your user can not have the right to access that function.
PetrH
enable below logger for validator com.ptc.windchill.esi.validators.AssociateDistributionTargetsActionValidator to DEBUG and check the logs generally the check is done for :
Check if user has read permission for ESI Target object
Check if user is a site administrator
Check if user belongs to one of the group specified in preference 'Enable ability to associate and remove
distribution targets'
Perhaps the user is not a member of one of the ESI groups?
https://www.ptc.com/en/support/article/CS71028
In the OOTB, there are two Site level groups, ESI Authors and ESI Administrators.
IIRC, Authors can assign distribution targets and Administrators can manually publish.
You can add users to these groups to convey the rights.
You might want to consider creating Org level groups and adding them to the sight level groups, as user membership is easier to manage at the Org level groups page.
Casey
