I am installing Windchill PDMLink as per Installation and Configuration Guide in a lab environment. There are 3 servers as following installed and configured in the same order. All servers have got no AV, FW disabled, UAC disabled and in same network.
Installation went smooth. After installation, ran following command for the sake of updating model and loading reports.
It generated an error as following. Any idea why and how I can fix this?
2018-04-14 21:04:45,385 ERROR [main] wt.method.MethodResultException - Metadata Provider Error
Exception in thread "main" (wt.fc.fcResource/0) wt.util.WTException: The operation: "updateThirdPartyReportModel" failed.
Nested exception is: wt.method.MethodResultException: *ERROR* Server side Exception has occured: See MethodServer log for details
at com.ptc.windchill.cognos.CognosFacade.handleThrowable(CognosFacade.java:3610)
at com.ptc.windchill.cognos.CognosFacade.updateModel(CognosFacade.java:498)
When checked method server log, found below error
2018-04-14 21:04:45,354 ERROR [RMI TCP Connection(36)-192.168.30.62] wt.method.MethodContextMonitor.contexts.rmi wcadmin - 2018-04-14 21:04:26.428 +0400, nzzuoyu;jfzmfzmz;3352;83tmp9;1, -, -, -, wcadmin, 192.168.30.62, com.ptc.windchill.enterprise.report.StandardReportService, updateThirdPartyReportModel, , 0, 10, 0.57966848, 5, 0.01462208, 7.203125, 18.88792576
wt.util.WTException: Metadata Provider Error
Nested exception is: AxisFault
faultCode: Client
faultSubcode:
faultString: Metadata Provider Error
faultActor:
faultNode:
faultDetail:
{http://developer.cognos.com/schemas/bibus/3/}exception:<ns1:severity>Error</ns1:severity><ns1:errorCode>BME-AS-0021</ns1:errorCode><ns1:message><ns1:messageString>BME-AS-0021 Unable to open the model.
</ns1:messageString><ns1:nestingLevel>1</ns1:nestingLevel></ns1:message>
Thank you,
This issue has been fixed after few trial and errors.
It is found that only FixPack 2 should be applied to Cognos 10.2.2 though FixPack is available from IBM site. The whole thing was that even PTC support technicians confirmed to install FP10 and gave wrong configuration. After installation of FP2 without changing any further property values, I could update the model and load reports successfully.
