Updating user details in Windchill
jjoe-2
i would like to update 300 email ids of users in windchill so is there a way to do it other than manually doing it for each account?
BineshKumar1
(To:jjoe-2)
There are several ways of doing it.
1. Java API, write a utility to update the email
try {
     QuerySpec qs = new QuerySpec(WTUser.class);
     qs.appendWhere(new SearchCondition(WTUser.class, WTUser.EMAIL, SearchCondition.LIKE, "oldemail@oldemail.com", true), null);
     QueryResult qr = PersistenceHelper.manager.find((StatementSpec) qs);
     while (qr.hasMoreElements()) {
  WTUser user = (WTUser)qr.nextElement();
  user.setEMail("someone@something.com");
  PersistenceHelper.manager.save(user);
  } catch (WTException | WTPropertyVetoException e) {
     // TODO Auto-generated catch block
     e.printStackTrace();
2. Update WTUser database table, email field
3. Use infoengine Webject
<%@page language="java"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
<ie:webject name="Get-Properties" type="MGT">
    <ie:param name="AUTHORIZATION" data="${@SERVER[]authorization[]}"/>
    <ie:param name="ATTRIBUTE" data="wt.federation.ie.VMName"/>
    <ie:param name="GROUP_OUT" data="properties"/>
</ie:webject>
<ie:webject name="Update-Objects" type="ACT">
    <ie:param name="INSTANCE" data="$(@FORM[]supporting-adapter[*])" delim="!" valueSeparator="!" default="<%=com.infoengine.au.NamingService.getVMName()%>"/>
  <ie:param name="INSTANCE"        data="${properties[0]wt.federation.ie.VMName[0]}"/>
    <ie:param name="DBUSER" data="wcadmin"/>
    <ie:param name="PASSWD" data="wcadminpasw"/>
    <ie:param name="GROUP_OUT" data="Users"/>
    <ie:param name="TYPE" data="wt.org.WTUser"/>
    <ie:param name="FIELD" data="mail=someone@something.com"/>
    <ie:param name="WHERE"        data="uid=wcadmin"/>
</ie:webject>
BineshKumar1
(To:jjoe-2)
try {
</ie:webject>
</ie:webject>
Hello Binesh, As email field also sits in Windchill DS, It doesnt look like the API will update that, any thoughts?
Hello,  BineshKumar1, please tell me how you can use the first option to add a new value to the table ( a new line)?
I created a separate topic on this issue https://community.ptc.com/t5/Windchill/How-do-I-add-new-values-using-QuerySpec/m-p/646594
