I am considering a contract job to upgrade a client from Windchill 7.0 to 9.1 M050. Any suggestions on what path to take performing this upgrade? Any complications I should look out for?
Thanks in advance for any input on this.
Lev Desmarais
Implementation Consultant
Guru Programming
See the "Windchill Supported Upgrade Paths" in the attachment
We took someone from 6.2.6 to 9.1 and we had to jump versions so from 6.2.6 to 7.0 to 8.0 to 9.1, you may want to look into doing the same to ensure proper conversion of all data as a direct jump from 7.0 to 9.1 may bring you more headaches than it is worth. Also be prepared to open up some calls with PTC and factor in some extra time to buffer for this.
