If you are upgrading from 9.0 to 9.1, this is an UPGRADE not a service pack of a build of windchill. You have to use the upgrade procedure. See attached task list that might help you when you do an upgrade. It is a little outdated because of the new Windchill DS but all in all it works for me.
I would wait a couple of weeks for Windchill 9.1 M050 for RedHat 5.# ES with 2 intel quad/i7's (8 cores/12 cores) with unlimited DDR3 RAM. It isvery fast.
I have tested this against HP-UX itaniums, HP-UX Risc and intel dual cores with the same total number of core and I've seen 10X faster performance. We are now using HP BladesBL460C G6with a 10GIGE switch with oracle and the CAD worker Windows 7/200864bit/R2server(7 CAD workers). I just wish ProE was supported on Linux. With that many cores, you can have 6 method servers and 3 background method servers with 48 GIG of RAM.
We are also testing with rack mountable remote ProE workstations. The cost this architecture of server room based workstations to of upgrading the entire network is very convincing plus advantages including the added security. both Dell and HP have relatively the same solution. Dell has be great providing in-house testing for free. We haven't heard much from HP.
Give it a try.
My bad,
Thanks Alexius,
Becareful to make sure your Tomcat versions in in sync with Javalike version 6which issupported in 9.1.
Sorry guys,
Only had 2 hours of sleep last night due to my new born son.
I'm just confirming what is said above. You can stay with Oracle 10G which is set at 8K block size. You can always test/move to Oracle 11G with 16K block size and a better performance which is always depending system resources of RAM and CPU.
If you are rehosting a Windchill 9.0 application to point to an Oracle 11G database after an import, you need to add these lines to the Windchill 9.0 site.xconf:
<property name="wt.generation.sql.tinyBlobSize" overridable="true"<br"/> targetFile="codebase/user.properties"
value="32k"/>
<property name="wt.generation.sql.smallBlobSize" overridable="true"<br"/> targetFile="codebase/user.properties"
In the command line run the following:
xconfmangager -p
$WT_HOME/bin/JavaGen.shregistry false false true false false
this will reset all your SQLs to increment to 32K ratherthan8K which is less than the 16K for Oracle 11G. Plus, after an import all your data is now contiguous.
Then you are good.
value="32k"/>
