Fellow Intralinkers,
We are planning our migration to WF4.0 and would like your comments on our plan.
Currently we are using ProI 3.4 M030 with ProE WF2.0 M230.
First step we will upgrade ProE to WF2.0 M280.
Second step we'll upgrade ProI to 3.4 M062 with WF2.0 M280.
Finally we'll go to ProI 3.4 M062 with WF4.0 M080 or later.
After each step we will halt for tests.
Did you go through the same process with the same versions\build codes?
What is your experience? Would triggers work or do we need to recompile them or make changes due to Unicode? Any other comments?
Best Regards,
Shimon Michaelovich
CAD & PDM Engineer
RAFAEL
ISRAEL
