Upload / download files to/from Windchill with standalone browser.
sdrzewiczewski
7-Bedrock
In 9.1 you can download files from the object's details page > General >
Content table. It will not process any dependencies. So if you are looking
to get an assembly, it will just get the .asm file.
Steve D.
> I usually interact with pro/e data through the embedded windchill
> interface and only use a standalone browser to do admin stuff. A new user
> asked me how to download file content from the standalone browser, and I
> am at a loss. Any ideas? I notice that the "tools" pull down menu that
> allows you to import/export from a workspace only shows up in the embedded
> browser in pro/e.
> Sincerely
> Paul Bock
> Avox Systems
You could try to use the "Add to package" functionality from the property page of the assembly. This collects all dependencies and content files and writesthem to a archive. Unter utilities there is also aImport/Export Manager. As far as I know this shoulddo the same. The probably "unwanted" side-effect is thatthe system logs all this actions.
Regards
Klaus
Hello
I think you can also do the same independent file download, other than the details page.
From the Product/Folders Page (probably Library or other tables also), between the Name/Number Columns is a "Document Format" Column.
If you hover overan individualobject format icon, it will offer "Download <format> File" hyperlink selection.
It also only downloads an non associated single file.
I have seen this on 2 systems, so I dont think there is any configuration/preference edit needed.
L Jett
Of course, this is for WC 9.1 M040.
L Jett
cc-2
6-Contributor
(To:sdrzewiczewski)
Import/export is only available in the client side workspace table.
