I am having the same issue as this topic: https://community.ptc.com/t5/Windchill/Upload-failure-starting-quot-Upload-Failure-code-J03-WCCLD/m-p/384733#M45043 , we are on ePDM 12, Creo 11.0.4 any ideas what could cause this?
There can be many. I searched for that in the knowledge base and many articles came back. Some point to upload sizes, vpn issues, local cache
https://www.ptc.com/en/support/article/CS443107?source=search
https://www.ptc.com/en/support/article/CS378267?source=search
https://www.ptc.com/en/support/article/CS383037?source=search
https://www.ptc.com/en/support/article/CS322959?source=search
https://www.ptc.com/en/support/article/CS437608?source=search
There are more but please provide more that your version. Does it repeat? Is it a large file? All users? Intermittent?
Hi Avillanueva,
what I did is, borrowed a Creo license, disconnected from VPN, and this actually worked, not sure why would VPN cause an issue, never happened before, clearing the cache didn't help, the file size if fairly large, but yes bottom line, it was the VPN.
thank you so much for researching this, I will keep it for our records.
