We have several Excel doc's (and maybe a Word doc or two) that users regularly fill out as part of their tasks.
There are several pieces of information in those doc's that we'd like to capture as Attributes in WC.
Rather than have the users manually enter the Attribute during document creation or check-in in WC, is there a way to have WC "detect" the presence of information in Named cells, and use that information to populate an Attribute?
Right now we have the users check-in the document, and manually specify the info for the selected Attributes in the Set Attributes screen. Not only is this duplicating work, it also presents an opportunity for the actual Excel document to say one thing, while the Attributes say another. I'd like to leverage that data that's already in the Excel doc!
Through searching, I found a pretty good blurb from someone about how to map the IBAs to Named cells in Excel...but this only appears to work when Attributes are already established for an Excel doc and you want to get an Excel file to "update" to show the values of those Attributes in the Excel file. Its outbound info only, not inbound info creation.
Thanks!
