We have a system that has so far used Assigned Expression, we are exploring the functionality of Independent Expressions and can we make use of the same. As I understand, once the system is made ready for Independent Exp, all defined expression will also be converted into Independent Exp. I wanted to understand the impact of doing it and when should we think about doing the conversion.
TIA.
HS
Just so those on board know, this is related to options and variants.
