User creation
Amirtharaj_K
User creation
Hi Guys,
I have a few changes to User creation like the below image adding the new attributes, but the alternative user does not work. Whatever I entered didn't save in attributes.
Thanks in Advance,
Amir
Hi @Amirtharaj_K
Check create and edit layout in the type and attribute management.
Is the following picture more clear?
PetrH
7 REPLIES 7
How we can sync with LDAP
Hi @Amirtharaj_K
Check if the Alternate user name has a datautility defined - userDataUtility
If you remove the attribute from the UI then you need to redefine the DAtAUTILITY when you add the attribute back to grid UI
PetrH
Hi Mr. Petr, Thank for the replayed.
I didn't know where i can get the "Data Utility ID", can you brief more on that.
Once again Thanks so much for your supporting me, I learned lot of thing from you.
Amir
Hi @Amirtharaj_K
PetrH
Hi Mr. Petr
I apologize for the delayed response, Thanks for your Support. It's working now.
I have one more doubt about the creation of new/edit users. Is it possible to set a default postal address input value or utilize a drop-down list?
Amir
Hi @Amirtharaj_K
The type attribute management allows you to set the default value
but in some cases the default value is not set because it is leaded from rbInfo configuration.
PetrH
Thanks for the additional information Mr. Petr.
