We are planning on upgrading to creo elements/pro 5 (build M090) shortly. We will be using it with PDMLink 9.1/m40
We have evaluated this build and have not encountered any "show stopper" type issues.
Before we "jump in", I was doing a last check to verify if you have encountered any issues either with Pro/E or with it's PDMLink interaction that we should be aware of.
Thanks in advance for a prompt reply!
Tom Hogan
thomas_hogan@verizon.net
Hi Tom,
For our client using Windchill 9.1 M060 we went ahead withelements/pro 5 (build M100) few months back. Everything is okay but we faced two issues:
ISSUE 1 )
We publish the drawigs to PDF. The PEN table entries for CAD worker had to be changed. The pen number assigned to each entity is based on entity color in withelements/pro 5. Previously the width of plotted lines was related to the 150369 for further details.
ISSUE 2 )
Few of the old drawings showed diognal random lines acrros when the drawings were published /exported to PDF. The issue was with few old drawings created in Wildfire 3. PTC provided a config setting to fix the issue.
Apart from the two minor issues above...rest everything is fine.
~Vaibhav
In Reply to Tom Hogan:
Tom Hogan
