Users of one region belonging to one domain are not able to login to Windchill.
Windchill is configured with AD group which has users from 3 domains. Suddenly it stopped working for 1 domain, is there anything needed to be done at Windchill end?
What does the MS Logs catch?
The cause may be outside Windchill. You need to check the logs.
Rgds
Hari
Rgds
Hari
@Hari_Vara Yes, you are correct. It is found to be an issue in active directory for a particular domain.
