Using Eclipse
dkessler
6-Contributor
Using Eclipse
Documentation 10_MR040_WindchillCustomizationGuide.pdf on page 51 it shows project cust_Windchill_src in Eclipse. In order to load that project in you must follow directions from ant -f bin/tools.xml eclipse_project.help I followed these directions. Step 1) Run the eclipse_project task is too vague. I can get the cust_Windchill_src folder into the project window of Eclipse, but I have no supporting libraries or src folders. Can anyone explain what "run the eclipse_project task" actually means? I put in Filesync, but I am not sure it is working. Thanks.
Nitin
7-Bedrock
(To:dkessler)
Step 1) Run the eclipse_project task.
this implies running the ant command as below -
C:\ptc\Windchill_10.0\Windchill>ant -f bin/tools.xml eclipse_project
It is basically creating a workspace and placing .classpath and .project filesin this workspace.
Further as the eclipse_project.help says, the newly created workspace and projects are used.
Hope this helps.
-Nitin
7 REPLIES 7
Nitin
7-Bedrock
(To:dkessler)
Hope this helps.
-Nitin
dkessler
6-Contributor
(To:Nitin)
Okay that makes sense. It worked, thanks.
Still I am not able to find the cust_Windchill_src can u please explain clearly about the issue, I run the command and is is working properly.
vbabu-3
(To:reetakota)
Hi  Reetakota,
Steps:
1. Install JRE/JDK and Eclipse.
2. Run the commands: ant -f bin/tools.xml eclipse_project.help
You will find the cust_Windchill_src folder in the  Eclipse Workspace Directory.
If you go with by default options, it will be created under the <Windchill>\eclipse\cust_Windchill_src folder
Attached is a snapshot, FYI.
Venkat
B-WI
isodius
(To:vbabu-3)
It is the second Ant call that is crucial. That line is not present on page 56 of the current 11_F000 version of the guide.
vbabu-3
(To:isodius)
Yes, it is!
That's what creates the Project folder, FYIP.
Venkat
Hello, there is a video of training for example from the documentation
https://www.youtube.com/watch?v=-14BSAwteVw&list=PLjm4gmbLQwoeqQSP7xUhCnInGknqTBAZV&index=2
Basic Customization Getting Started With Windchill Customization https://support.ptc.com/help/wnc/r11.2.0.0/en/index.html#page/Windchill_Help_Center%2FWCCG_Oview_GetStartCust_Intro.html%23
