Has anyone had any experience with using ProjectLink purely as a means to share large CAD files with a supplier? Obviously it has much more power than that, but for now, our users really only want a place to use as a ‘dropbox’ of sorts, that has some access controls around it. Therefore, we would want a dumbed down UI because it tends to make the page too confusing for new users. Is anyone else using it only for that purpose or have found a better way to share files that are in the 100 MB+ range.
There are, but I'm not sure if you'll get a response from them. This is a big, powerfull capability of Windchill. If you're intent is to keep the data connected to your Windchill system, this is the way to go. If it is for one-off colaboration with low levels of interaction, you can put a Package in the project so colloborators only have one item to pick up and download.
