I'm trying to use the newMultiObjectCopy API from wt.enterprise.EnterpriseHelper and get
the error below.
javax.servlet.ServletException: wt.util.WTException: The value of "Owner Application" cannot be set to null, since it is a "required" attribute. Verschachtelte Ausnahme ist: Der Wert von "Besitzer-Anwendung" kann nicht auf null eingestellt werden, da es ein "erforderliches" Attribut ist. org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:862) org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:791) org.apache.jsp.netmarkets.jsp.nexiles.test_jsp._jspService(test_jsp.java:128) org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70) javax.servlet.http.HttpServlet.service(HttpServlet.java:717) org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:374) org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:342) org.apache.jasper.servlet.JspServlet.service(JspServlet.java:267) javax.servlet.http.HttpServlet.service(HttpServlet.java:717) com.ptc.core.components.filter.JCARedirect.doFilter(JCARedirect.java:228) wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:48) wt.httpgw.filter.TrustedAuthFilter.doFilter(TrustedAuthFilter.java:123) wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:232) wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:324) wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1417) wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:54)
I've reduced the code to the following test case. This code runs w/o error on a Windchill 10.0 instance,
but I need to deploy on Windchill PDMLink 9.1.
<%@ page import="wt.fc.ReferenceFactory"%>
<%@ page import="wt.epm.EPMDocument"%>
<%@ page import="wt.epm.EPMContextHelper"%>
<%@ page import="wt.epm.EPMApplicationType"%>
<%@ page import="wt.enterprise.EnterpriseHelper"%>
<%@ page import="wt.enterprise.RevisionControlled"%>
<jsp:useBean id="wtcontext" class="wt.httpgw.WTContextBean" scope="request"/>
<jsp:setProperty name="wtcontext" property="request" value="<%=request%>"/>
<% response.setContentType("text/plain; charset=UTF-8"); out.println("#START"); ReferenceFactory RF = new ReferenceFactory(); String oid = "OR:wt.epm.EPMDocument:121033"; EPMDocument assembly = (EPMDocument)RF.getReference(oid).getObject(); out.println("name=" + assembly.getName()); out.println("ownerapp=" + assembly.getOwnerApplication()); RevisionControlled arr[] = new RevisionControlled[1]; arr[0] = assembly; EPMContextHelper.setApplication(EPMApplicationType.toEPMApplicationType("EPM")); out.println(EnterpriseHelper.service.newMultiObjectCopy(arr)); out.println("#-------------------------------------------------"); %>
Output (windchill 10, expected):
#START name=rad.asm ownerapp=EPM [Lwt.enterprise.CopyObjectInfo;@903216a #-------------------------------------------------
Any pointers would be very welcome.
Stefan.
I understand it is pretty old stuff and not sure whether it is resolved or not... but still pasting working code snippet which I test yesterday.
I hope it help all community members!
RevisionControlled copyRC = null;
RevisionControlled afterSave = null;
final Transaction trx = new Transaction();
try{
trx.start();
final EPMDocument mdl = epm;
copyRC = EnterpriseHelper.service.newCopy(mdl);
final EPMDocument copy = (EPMDocument) copyRC;
copy.setName(mdl.getName() + "_copy");
copy.setNumber(mdl.getNumber() + "_copy");
copy.setContainer(mdl.getContainer());
copy.setOwnership(mdl.getOwnership());
copy.setCADName("TestCopyFile.drw");
afterSave = EnterpriseHelper.service.saveCopy(mdl,copy);
trx.commit();
System.out.println("Model has been saved, transaction completed: " + afterSave.getName());
catch(final Exception e){
System.out.println(e.toString());
trx.rollback();
