trying to export a lifecycle template from windchill v10...but getting the following error
(wt.lifecycle.lifecycleResource/224) wt.util.WTException: Do not support export on a disabled life cycle template.
2013-07-17 17:32:56,437 INFO [RMI TCP Connection(175)-10.171.33.5] wt.system.out aub_admin - at wt.lifecycle.LifeCycleExportImportHandler.exportTemplateAsStringBuffer(LifeCycleExportImportHandler.java:175)
The lifecycle template is however enabled! Has anyone seen this before??
I would verify that the lifecycle is enabled in the database. Something like
SQL> select name, enabled from lifecycletemplatemaster where name like '%<template_name>%';
Enabled column should be 1.
If that's set to 1 then you should probably open a tech support case to take a further look into it.
