Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
We are getting this error message on several objects in the workspace that is preventing them from being checked in or even uploaded. When trying to check in or upload it fails with this message:
"Referential integrity violations occurred for this operation:"
That is all it says, nothing else is listed to tell us what the problem is. There are no ghost objects related to the parts that we are attempting to upload or check in. There are no external references in the parts, all required or related items are present it the work space.
