Version Series Oracle Table
pwilliams-3
10.1 M040
Is the "seriessortvalue" table in oracle the correct table from which to query a file based versioning series?
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CFDE47.8AB31470]
If you want to look at the FileBased Version Series, you can execute the
following command from a Windchill shell.
windchill wt.series.LoadFileBasedSeries "C:\filebasedseries.xml" -read
It will create an xml file in your C: drive
Yes thanks Ryan. I know about this functionality. I was wondering if Windchill read my imported xml file into a database table. But, as it turns out, Windchill loads the file into a BLOB in the SERIESTEMPLATE table.
[cid:image002.jpg@01CFDE49.C51C9F80]
