Version not getting updated in Windchill.
prawat
3-Newcomer
Hi All,
When I am trying to upload a drawing it is failing with below error"
A referential integrity violation occurred for this operation:
Object "CAD Document Reference Link - wt.epm.structure.EPMReferenceLink:1752639662" references the object "wt.epm.EPMDocumentMaster:1752639465" that was removed from the system."
Version is not updating in windchil, PFA.
Thanks in advance.
BenLoosli
(To:prawat)
Check in the assembly file, then check in the drawing.
I am getting a similar problem . I tried checking in the part alone first but still it is throwing the same error.
A referential integrity violation occurred for this operation: Object "CAD Document Reference Link - wt.epm.structure.EPMReferenceLink:9874358477" references the object "wt.epm.EPMDocumentMaster:9874358415" that was removed from the system.
BenLoosli
(To:ssenguttuvan)
Is it a family table part instance?
No. It is a newly created single part and its drawing
BenLoosli
(To:ssenguttuvan)
We had that issue with a part the other day and it was the format was showing as being modified in the workspace, but the user had no rights to check in a format.
I renamed the format in his workspace, then replaced the format with the proper system named format. This allowed me to check in his drawing and then I deleted the dummy-named format from his workspace. I did this on his system logged in as him, so no admin rights like my username would have ha.
