Veto Reviewer Workflow
StuartHarvey
My customer needs a workflow where an optional set of reviews have veto power.  Any of the optional reviewers can cast the veto and workflow should run through a reject path.   I would like to utilize roles to define this activity.
Does anyone have an example of a veto reviewer workflow?
See whether this thread helpsSOLUTION: Change Management w/ multiple approvers
You can create a group of veto reviewers and validate the principal in workflow as well
Check the help center, I recall some code examples there that are at least close to your use case.  If I remember correctly it's under Customizing Change Management.
