WC10.1 .qml report for ACL policy rules attached
DarrenStorey
Noticed my 9.1 report for ACL policy rules did not work in 10.1.
Attached is a 10.1 reworked version in case anybody has need. Personally I find it hard to get a decent overview using policy admin util.
Darren
How does your qml compare to what is output from WINDU?
I haven't looked at in any detail.
[cid:image001.jpg@01CF2EE6.B3A0F660]
[cid:image002.png@01CF2EE6.B3A0F660]
Mike, in terms of data content, not a great deal different. A few extra fields.
However I'll take the live HTML report that I can pull into an Excel pivot table over a static text dump any day.
Thanks for the attached qml. Always nice when content added, will likely save time later.
I one time wrote java code to parse the windu output & create separate text & xml (for loadfromfile).
It would also break the text & xml into smaller, per container files, so the admin could go to a text/dev/sandbox install
& import in for just one container.
But that was for 9.1. I wonder how messed up &/or different the windu for policy output is.
I might have to update the java code for 10.1 sometime.
Larry Jett
Hi Larry
I have used your ACL windDU parsing tool in the past. FYI I did already try using it with 10.1 but it does not work.
Darren
