I have installed Windchill 10.2 m030 on a test machine and when I run Windchill Configuration Assistant, it fails at the encryptpassword stage.
I have attached the last WCA log file.
Windows 2008r2 64-bit AMD Opteron Quad core
Windchill 10.2 m030
Did you try running Windchill shell as an administrator? It is complaining about access
Thank you
Binesh Kumar
Barry Wehmiller
Thank you
Binesh Kumar
Barry Wehmiller
