I trying to write some Workflow Activity instructions that include attributes (workflow variables) derived from enumerated lists chosen when creating the object. For example, we have a list of Technical Approves. Each approver has a unique internal name that is different from their display name.
The instructions need to say "talk with J. Baker about this" but they are coming out as "talk with TA_JBaker about this". The problem is even worse when the user's name has changed (i.e. through marriage their display name should now be J. Reynolds).
How can I tell the instructions to use the display name and not the internal name?
We are using Release 12.0.2.12 with PLMlink 12.0.2.7.
@HelesicPetrand @BjoernRueegg Thank you both for your help on this. I got the following code working. It extracts the display name of a Global Enumerated Value.
com.ptc.core.lwc.server.PersistableAdapter obj = new com.ptc.core.lwc.server.PersistableAdapter(primaryBusinessObject,null, java.util.Locale.US, new com.ptc.core.meta.common.DisplayOperationIdentifier());
obj.load("my_enum_attribute");
Object enumValue = obj.get("my_enum_attribute");
System.out.println("Attribute Value = internal name of Enumerated Value: " + (java.lang.String) obj.get("my_enum_attribute"));
//Returns TA_JBaker
com.ptc.core.meta.container.common.AttributeTypeSummary ats = obj.getAttributeDescriptor("my_enum_attribute");
com.ptc.core.meta.common.DataSet ds = ats.getLegalValueSet();
com.ptc.core.meta.common.EnumerationEntryIdentifier enumerationEntryIdentifier = ((com.ptc.core.meta.common.EnumeratedSet) ds).getElementByKey(enumValue.toString());
com.ptc.core.lwc.server.LWCEnumerationEntryValuesFactory lwcEnumerationEntryValuesFactory = new com.ptc.core.lwc.server.LWCEnumerationEntryValuesFactory();
//System.out.println(lwcEnumerationEntryValuesFactory.get(enumerationEntryIdentifier, java.util.Locale.US));
//Returns: {IS_SELECTABLE=true, displayName=J. Reynolds, display=J. Reynolds, abbreviatedDisplay=J. Reynolds, selectable=true, fullDisplay=J. Reynolds, sort_order=0}
wt.meta.LocalizedValues localizedValues = lwcEnumerationEntryValuesFactory.get(enumerationEntryIdentifier, java.util.Locale.US);
String enum_display_name = localizedValues.getDisplay();
System.out.println("Enumerated Value's Display Name: " + enum_display_name);
//Returns: J. Reynolds
You want to use user.getFullName() to see Display name.
But these are instructions written in the Activity tab of a task assignment node. Can I use code the activity tab? If so, that would be great. How though?
Right now I'm having to use: talk with {ta_name_wf} about this to show the value. Where ta_name_wf is the variable mapped to the attribute.
Hi @Ben_A
You need to create new variable where you fill the display name by code, and you use this attribute in the instructions.
PetrH
Thanks for the help. I believe we're getting closer. I'm not actually after a user object class info. Just any value from an enumerated list.
This is my code so far. It returns the internal name of the enumeration, TA_JBaker but not the value which is "J. Reynolds"
com.ptc.core.lwc.server.PersistableAdapter obj1 = new com.ptc.core.lwc.server.PersistableAdapter(primaryBusinessObject,null, java.util.Locale.US, new com.ptc.core.meta.common.DisplayOperationIdentifier());
obj1.load("attrib_enum_username");
username_wf = obj1.getAsString("attrib_enum_username");
System.out.println(username_wf);
I can't find a method in PersistableAdapter to getDisplayName of the enumeration.
Hi @Ben_A
Because the method does not exists
CS133237-How to programmatically get the Display Name for Global Enumeration entries
You need to find unsupported method that exists in the system.
PetrH
Hi @Ben_A
edit: oh this code does not work as I expected... sorry
Here is unsupported code to get value from IBA.
String iba_name = "ATRIBNAME";
String iba_value = "";
try {
String name="";
Object primaryBusinessObject = null;
wt.iba.value.IBAHolder obj_iba_holder = (wt.iba.value.IBAHolder) primaryBusinessObject;
wt.iba.value.IBAHolder iba_holder = wt.iba.value.service.IBAValueHelper.service.refreshAttributeContainer(obj_iba_holder, null, wt.util.WTContext.getContext().getLocale(), null);
wt.iba.value.DefaultAttributeContainer default_attribute_container = (wt.iba.value.DefaultAttributeContainer) iba_holder.getAttributeContainer();
for (wt.iba.value.litevalue.AbstractValueView abstract_value_view : default_attribute_container.getAttributeValues()) {
name = abstract_value_view.getDefinition().getName();
if (iba_name.equalsIgnoreCase(name)) {
iba_value = wt.iba.value.IBAValueUtility.getLocalizedIBAValueDisplayString(abstract_value_view, Locale.getDefault());
break;
} catch (RemoteException | WTException e) {
e.printStackTrace();
System.out.println("display Value: " + iba_value);
PetrH
Hi @Ben_A
Why do you use PersistableAdapter method ?
Why do you not use the WTUser object?
example:
wt.org.WTUser wtUser = (wt.org.WTUser) wt.org.OrganizationServicesHelper.manager.getPrincipal("admin");
String userDisplayname = wtUser.getPrincipalDisplayIdentifier();
if you have correct user internal values you can search for the principal, and get the display name from the user.
PetrH
Hi @Ben_A
Here I introduce a code to get enumeration display name. It is complicated but it works.
Input is internalValue of the parameter.
iba_internalvalue = "internalValue";
QuerySpec qs = new QuerySpec();
int idxLWCLocalizablePropertyValue = qs.appendClassList(LWCLocalizablePropertyValue. class, false);
int idxLWCEnumerationEntry = qs.addClassList(LWCEnumerationEntry.class, false);
int idxLWCPropertyDefinition = qs.addClassList(LWCPropertyDefinition.class, false);
qs.appendSelect(new ClassAttribute(LWCLocalizablePropertyValue.class, "value"), new int[] { idxLWCLocalizablePropertyValue }, false);
qs.appendWhere(new SearchCondition(LWCEnumerationEntry.class , LWCEnumerationEntry.NAME , SearchCondition.EQUAL, iba_internalvalue), new int[] { idxLWCEnumerationEntry });
qs.appendAnd();
qs.appendWhere(new SearchCondition(LWCLocalizablePropertyValue.class ,"holderReference.key.id" ,LWCEnumerationEntry.class,"thePersistInfo.theObjectIdentifier.id"), new int[] {idxLWCLocalizablePropertyValue, idxLWCEnumerationEntry});
qs.appendAnd();
qs.appendWhere(new SearchCondition(LWCLocalizablePropertyValue.class ,"propertyReference.key.id" ,LWCPropertyDefinition.class,"thePersistInfo.theObjectIdentifier.id"), new int[] {idxLWCLocalizablePropertyValue,idxLWCPropertyDefinition});
qs.appendAnd();
qs.appendWhere(new SearchCondition(LWCPropertyDefinition.class , LWCPropertyDefinition.NAME , SearchCondition.EQUAL, "displayName"), new int[] { idxLWCPropertyDefinition });
QueryResult qr = PersistenceHelper.manager.find(qs);
while ( qr.hasMoreElements() ) {
Object obj[] = (Object [])(qr.nextElement());
System. out.println("Enumerations display name is: " +obj[0].toString());
Hope this can help you with enumeration iba values.
PS> it works if the internal name is used juts once in one enumeration list. If the internal name is used in two different lists then you need to search the correct one.
PetrH
Or something like this. The LocalizedValues variable has all information you need.
See also: CS204076
public static LocalizedValues getDisplayValueFromEnumerationAttribute(Persistable persistable,
String attributeName,
Locale locale)
throws WTException {
/* load object */
PersistableAdapter obj = new PersistableAdapter(persistable,
null,
locale,
new DisplayOperationIdentifier());
obj.load(attributeName);
Object enumValue = obj.get(attributeName);
AttributeTypeSummary ats = obj.getAttributeDescriptor(attributeName);
EnumerationEntryIdentifier enumerationEntryIdentifier = ((EnumeratedSet) ds).getElementByKey(
LWCEnumerationEntryValuesFactory lwcEnumerationEntryValuesFactory = new LWCEnumerationEntryValuesFactory();
return lwcEnumerationEntryValuesFactory.get(enumerationEntryIdentifier, locale);
Bjoern
Hi @BjoernRueegg,
This looks to be exactly what I'm after. So Simple. However, I'm not sure how to use it. When I try to insert this method (excuse me if method is the wrong term) into my Workflow expression bot I get an error on syntax check.
WfExpression_13305573.java:124: error: illegal start of expression
public static LocalizedValues getDisplayValueFromEnumerationAttribute(Persistable persistable, String attributeName, Locale locale)
How, or where, do I put this code so I can access it from a WF expression bot?
Sorry for the late answer. To put the code into a workflow expression you need to specify all the different java package names, since there is no import function in any expression.
You could compile the code in an external class and call it from the expression. But all of that needs some customizing knowledge.
all classes have to be fully defined.
in your case you need to define all used classes
wt.fc.Persistable
java.util.Locale
PetrH
Ok. Adding the full class makes sense, so I updated my code as shown:
Everything up to the final line passes the syntax check.
obj.load("my_attribute");
Object enumValue = obj.get("my_attribute");
com.ptc.core.meta.container.common.AttributeTypeSummary ats = obj.getAttributeDescriptor("my_attribute");
String Output = lwcEnumerationEntryValuesFactory.get(enumerationEntryIdentifier, java.util.Locale.US);But I get this error at the final line:
Checking Syntax...
WfExpression_13305573.java:54: error: incompatible types: LocalizedValues cannot be converted to String
What exactly is the output from lwcEnumerationEntryValuesFactory.get(enumerationEntryIdentifier, java.util.Locale.US); and how can I convert it into a string? I can't seam to find it mentioned anywhere in the JavaDoc.
Hi @Ben_A
You can not use the String as a output because the .get function returns LocalizedValues
You need to get a string from the LocalizedValues object.
PetrH
//Returns TA_JBaker
