We are happy to announce the new Windchill Customization board! Learn more.
WGM 9.1 fails to launch after we have installed WGM 11.0
PhilippePradour
6-Contributor
In the meantime of a Windchill migration from 9.1 to 11.0 we have to run on a same client different versions of Solidworks and WGM (respectively 2012 with 9.1-M070 and 2016 with 11.0 M01) but WGM 9.1 fails to launch after we have installed WGM 11.0.
I tend to suspect this relates to the having a common Cache and Root with 2 different versions of WGM.
Is this a known issue ? Are there known resolutions (environment variables for Cache and Root) ?
Hi Philippe,
Please refer PTC Article on running multiple WWGM clients on same system. Even though 9.1 with 11.0 WWGM is not mentioned in the article, you can give it a try.
Document - CS212589
How to install and run multiple versions of the Windchill Workgroup Manager client on the same machine
Pankaj Mooteri
Product Manager, PTC
Hi Philippe,
Document - CS212589
Pankaj Mooteri
Hello Pankaj,
Thanks for the prompt and accurate answer. It looks good to me and this what I suspected.
I have forwarded to our team and they will test it and get back to PTC support if necessary.
Best regards,
Philippe
