Hi Guys,
After integrating with AutoCAD 2023, I was able to open the Windchill file in AutoCAD without issue, but when I attempted to save it as Auto Check-In, Check-In or Save, I received this error.
Amir
From "Autodesk Support":
Hi @Amirtharaj_K,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
