WGM SOLIDWORKS2016 opening Creo Part(.prt or .asm)
RAHUL
6-Contributor
Dear WC GURUS,
How to Open .prt or .ASM existing WIndchill file in WGM Solidworks in solidworks2016, Any suggestions or need to follow any specific process.
(Getting this error :
Failed to open in SolidWorks 2016: lp-tm-p-test-clamp-115.prt. <C:\Users\eb010956\Documents\PTC Places\Workspace\lp-tm-p-test-clamp-115.prt> does not exist.
All open suggestion are welcome.
RAHUL
BineshKumar1
(To:RAHUL)
I don' t think this is a supported use case for WGM. WGM doesn't allow you to open Creo authored files in SW. The last time I tried, It doesn't even allow neutral files created in Creo to be opened in SW
Rahul - @BineshKumar1 is corrrect. This use-case is not really supported. If you can elaborate on the use-case and what you are trying to accomplish, we might suggest some alternate workflows.
You should be able to export / Save A Copy >> SolidWorks from Creo (you will need the Collaboration Extension for SolidWorks licenses in Creo) and then open that in SolidWorks via the WGM.
Mark
RAHUL
6-Contributor
(To:MarkLobo)
Thank you for your valuable suggestion
Mark
