SW2022 SP5 -WGM 13.0.1.0 and Windchill Release: 12.0.2.23
how do/can I map Windchill template folder path in Solidworks ?
Windchill path is a url path ?
our creo9 path is defined as:
template_solidpart wtpub://pdm.covidien.com/Libraries/CADStandards/Templates/MNav/startpart__mm.prt
thanks
Rich
Hi @rburk you will be having a windchill file system location set on your machine, it's a virtual folder,
You can find it's location from Windchill Workgroup Manager> Tools > Windchill file system management
Browser to this Virtual folder from solidworks- PTC places/Commonspace/<your template folder>
This should set the location for the templates
Hope this helps!
Maybe these could help
https://www.ptc.com/en/support/article/CS116771
The latter is for 13.1.1.0, we're on 12.1.2.5 and I'm confident we haven't built it that way... need to study that myself!
Hope this helps!
found the path, thanks
working now
