I'm using Windchill PDMLink Release 11.1 CPS M020-CPS14, and I'm trying to install WGM. However, it fails to install WFS. When I try to run the WFS MSI installation, I get a "Could not open key" error. Do you know how I can fix this error?
It wasn't solved.
Is it a problem with the WGM version? Can I install a more recent one?
I checked in the matrix, and the CAD version is compatible with WGM 12.0, but is it compatible with WCH 11.1?
What version of WGM are you installing?
11.1 CPS M020-CPS14
Version 11.1 has not been supported for years, and 12.0.2 has also been out of support since June 2024.
This is the document with the compatibility matrix.
