WGM for AutoCAd Batch Loading of Drawings
borourke
7-Bedrock
We had a user attempt to batch load several drawings. It seems only the first drawing had the comments field filled out and pulled the attributes from the drawing's title block during the checkin process, the others were blank. Anyone know how to propagate these values across all of the drawings being checked in?
PreetiGupta
(To:borourke)
This is a very strange situation here. I have been trying to bulk index
some 600,000+ object in Windchill using out of the box M045 bulk-index
tool. The bulk indexing process gets stuck on certain object count and
it is repeated.
PTC tech support provided me a new java file BulkIndexHelper.java to
run the test. Bulk indexing is successful with this new tool. But the
funny part is that this file come straight from WIndchil M040
installation(as per Tech support). Earlier we decided to go to WIndchill
M045, as it was advertised that it has the "fixes" for Fast Search
issues.
I am not sure if anyone else has experienced similar issue with
Windchill M045 bulk-indexing. Now I strongly believe that Fast Search
bulk indexing tool M045 is broken.
Preeti
This e-mail (including any attachments) is confidential and may be legally privileged. If you are not an intended recipient or an authorized representative of an intended recipient, you are prohibited from using, copying or distributing the information in this e-mail or its attachments. If you have received this e-mail in error, please notify the sender immediately by return e-mail and delete all copies of this message and any attachments.
Thank you.
I have a similar issue that the bulkindex status remains on:
PreetiGupta
(To:borourke)
Yes I have seen SAME behavior. I have run this test for 9 times, its
repeated each time. We ran through several trials, Fast Technicians also
worked with us. Finally It turns out that the M045 bulk-index tool is
broken.
Then tech support provided me a java file from Windchill M040 system and
it completed bulk indexing successfully with this M040 file/tool.
Preeti
