Windchill 10.2 M20 WGM. Message when opening WGM. " ! A shared folder is selected for Windchill File System" The event viewer offers no info. What causes or how do I find out.
It sounds like you're getting the same error message as in CS167483. Take a look at this article and see if it helps:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS167483
Thank you. I don't know what the conflict is but setting to an unused folder seem to clear message. We don't use Solidworks so not sure if this is something that is application sensitive. I'm going to do a little more digging to understand what this variable is for. I did something to trip the error state.
