Hi All,
Trying to install WC 11, M030 on windows 10 (64 bit). After having done the initial setup, when the PSI proceeds to install, it progresses to 6-7% and then quits. Here's what the log says :
2018-01-29 14:58:11 - ###################################################
INFO 2018-01-29 14:58:11 - Running javasdk Installer
INFO 2018-01-29 14:58:11 - ###################################################
DEBUG 2018-01-29 14:58:11 - calling executeInstaller(E:\WC\MED-60703-CD-110_M030_Java development kit (JDK) for windchill 11.0)
DEBUG 2018-01-29 14:58:11 - Processing subinstaller assembly (javasdk): timer.start
INFO 2018-01-29 14:58:11 - Running: /usr/local/bin\cscript.exe //E:vbscript E:\WC\MED-60703-CD-110_M030_Java development kit (JDK) for windchill 11.0\setup.vbs WAIT LAX_VM C:\Users\root\AppData\Local\Temp\I1517217846\Windows\resource\jre\bin\java.exe -f E:\ptc\PSI\installer\PSITempProps\javasdk-installer.properties -DMULTI_PROGRAM_EXEC=1
ERROR 2018-01-29 14:58:11 - java.io.IOException: Cannot run program "/usr/local/bin\cscript.exe": CreateProcess error=2, The system cannot find the file specified
DEBUG 2018-01-29 14:58:12 - Installation is Aborting. The installation cannot continue.
FATAL 2018-01-29 14:58:27 - Aborting installation.
FATAL 2018-01-29 14:58:27 - Installation is Aborting. The installation cannot continue.
FATAL 2018-01-29 14:58:27 - javasdk installation has failed.
FATAL 2018-01-29 14:58:27 - aborting: original exit_code = 2
FATAL 2018-01-29 14:58:27 - aborting: normalized exit_code = 2
DEBUG 2018-01-29 14:58:27 - SHUTDOWN REQUESTED
DEBUG 2018-01-29 14:58:27 - (X) commiting registry
DEBUG 2018-01-29 14:58:27 - (X) shutting down service manager
DEBUG 2018-01-29 14:58:28 - (X) cleaning up temporary directories
DEBUG 2018-01-29 14:58:28 - Exiting with exit code: 2
DEBUG 2018-01-29 14:58:28 - Exception in thread "Thread-41"
DEBUG 2018-01-29 14:58:28 - Flexeraacf$aac: Cannot run program "/usr/bin/sh": CreateProcess error=2, The system cannot find the file specified
DEBUG 2018-01-29 14:58:28 - at Flexeraacf$aaa.run(Unknown Source)
DEBUG 2018-01-29 14:59:05 - FCBatch: Could not run script C:\Users\root/cbe.5120fade161413f148e : Exception in CertifiedBourneExec.doExec(): Died waiting for stdout/stderr pipes.
DEBUG 2018-01-29 14:59:05 - Exception in thread "Thread-42"
DEBUG 2018-01-29 14:59:05 - Flexeraacf$aac: Cannot run program "/usr/bin/sh": CreateProcess error=2, The system cannot find the file specified
DEBUG 2018-01-29 14:59:05 - at Flexeraacf$aaa.run(Unknown Source)
DEBUG 2018-01-29 14:59:43 - FCBatch: Could not run script C:\Users\root/cbe.e89b6a92161413fa6c7 : Exception in CertifiedBourneExec.doExec(): Died waiting for stdout/stderr pipes.
DEBUG 2018-01-29 14:59:43 - cleanUp()
DEBUG 2018-01-29 14:59:43 - calling cleanUpUNIX()
DEBUG 2018-01-29 14:59:43 - Command.run(): Cannot run program "/bin/sh": CreateProcess error=2, The system cannot find the file specified
Tried setting up the java environments...but to no avail.
Updated the drivers as well..
Tried running the JDK from PTC as well. . But doesn't work.!
Any help would be highly appreciated...
Hi @mkh
I think the PSI doesn't detect Windows 10, because the first error is UNIX Path
Thanks for replying. Please find attached the log.
Have renamed just to make things easy and avoid confusion- i have kept the extracted and zipped files in the same place. Have a look:
Awaiting your reply!
The running command used by PSI is incorrect
Exemple in my log:
INFO 2017-01-09 14:38:47 - Running: C:\Windows\system32\cscript.exe //E:vbscript etc...
Yours:
I think this is platform related, You can try same configuration on Virtual machine ( Windows 7/8 )
FYI i manage my sources like this:
Thanks for the renaming tip. Retrying again.
Used the method specified in Article - CS225837 to run the PSI...
Btw, have you installed WC11 on windows 10?
Only on 2012 R2 x64 and Ubuntu 16.04 sorry
I have installed Windchill 11.1 on Windows 10 with no errors. For previous releases I was using Windows 7...
![]() | Iker Mendiola - Prambanan IT Services |
To install windchill11.0 on windows 10, set following java option.
JAVA_TOOL_OPTIONS => "-Dos.name=Windows 7"
in environment variable => system variable
it worked for me
Thanks & Regards
Saravanan
