WINDCHILL INSTALLATION ON WINDOWS 10
mkh
11-Garnet
11-Garnet
Hi All,
Trying to install WC 11, M030 on windows 10 (64 bit). After having done the initial setup, when the PSI proceeds to install, it progresses to 6-7% and then quits. Here's what the log says :
2018-01-29 14:58:11 - ###################################################
INFO 2018-01-29 14:58:11 - Running javasdk Installer
INFO 2018-01-29 14:58:11 - ###################################################
DEBUG 2018-01-29 14:58:11 - calling executeInstaller(E:\WC\MED-60703-CD-110_M030_Java development kit (JDK) for windchill 11.0)
DEBUG 2018-01-29 14:58:11 - Processing subinstaller assembly (javasdk): timer.start
INFO 2018-01-29 14:58:11 - Running: /usr/local/bin\cscript.exe //E:vbscript E:\WC\MED-60703-CD-110_M030_Java development kit (JDK) for windchill 11.0\setup.vbs WAIT LAX_VM C:\Users\root\AppData\Local\Temp\I1517217846\Windows\resource\jre\bin\java.exe -f E:\ptc\PSI\installer\PSITempProps\javasdk-installer.properties -DMULTI_PROGRAM_EXEC=1
ERROR 2018-01-29 14:58:11 - java.io.IOException: Cannot run program "/usr/local/bin\cscript.exe": CreateProcess error=2, The system cannot find the file specified
DEBUG 2018-01-29 14:58:12 - Installation is Aborting. The installation cannot continue.
FATAL 2018-01-29 14:58:27 - Aborting installation.
FATAL 2018-01-29 14:58:27 - Installation is Aborting. The installation cannot continue.
FATAL 2018-01-29 14:58:27 - javasdk installation has failed.
FATAL 2018-01-29 14:58:27 - aborting: original exit_code = 2
FATAL 2018-01-29 14:58:27 - aborting: normalized exit_code = 2
DEBUG 2018-01-29 14:58:27 - SHUTDOWN REQUESTED
DEBUG 2018-01-29 14:58:27 - (X) commiting registry
DEBUG 2018-01-29 14:58:27 - (X) shutting down service manager
DEBUG 2018-01-29 14:58:28 - (X) cleaning up temporary directories
DEBUG 2018-01-29 14:58:28 - Exiting with exit code: 2
DEBUG 2018-01-29 14:58:28 - Exception in thread "Thread-41"
DEBUG 2018-01-29 14:58:28 - Flexeraacf$aac: Cannot run program "/usr/bin/sh": CreateProcess error=2, The system cannot find the file specified
DEBUG 2018-01-29 14:58:28 - at Flexeraacf$aaa.run(Unknown Source)
DEBUG 2018-01-29 14:59:05 - FCBatch: Could not run script C:\Users\root/cbe.5120fade161413f148e : Exception in CertifiedBourneExec.doExec(): Died waiting for stdout/stderr pipes.
DEBUG 2018-01-29 14:59:05 - Exception in thread "Thread-42"
DEBUG 2018-01-29 14:59:05 - Flexeraacf$aac: Cannot run program "/usr/bin/sh": CreateProcess error=2, The system cannot find the file specified
DEBUG 2018-01-29 14:59:05 - at Flexeraacf$aaa.run(Unknown Source)
DEBUG 2018-01-29 14:59:43 - FCBatch: Could not run script C:\Users\root/cbe.e89b6a92161413fa6c7 : Exception in CertifiedBourneExec.doExec(): Died waiting for stdout/stderr pipes.
DEBUG 2018-01-29 14:59:43 - cleanUp()
DEBUG 2018-01-29 14:59:43 - calling cleanUpUNIX()
DEBUG 2018-01-29 14:59:43 - Command.run(): Cannot run program "/bin/sh": CreateProcess error=2, The system cannot find the file specified
Tried setting up the java environments...but to no avail.
Updated the drivers as well..
Tried running the JDK from PTC as well. . But doesn't work.!
Any help would be highly appreciated...
8 REPLIES 8
Vincent-Kulak
(To:mkh)
Hi @mkh
  • Windows 10 is unsupported even in "Development and Test Systems"
  • Please don't rename your folder source like that "MED-60703-CD-110_M030_Java development kit (JDK) for windchill 11.0" , my own but PTC hate that ( extra space, special character etc.. )
  • Please attach full log
I think the PSI doesn't detect Windows 10, because the first error is UNIX Path
Hi @Vincent-Kulak
Thanks for replying. Please find attached the log.
Have renamed just to make things easy and avoid confusion- i have kept the extracted and zipped files in the same place. Have a look: 2018-01-29 19_03_46-WC.png
Awaiting your reply!
Vincent-Kulak
(To:mkh)
The running command used by PSI is incorrect
Exemple in my log:
INFO   2017-01-09 14:38:47 - Running:  C:\Windows\system32\cscript.exe //E:vbscript etc...
Yours
I think this is platform related, You can try same configuration on Virtual machine ( Windows 7/8 )
FYI i manage my sources like this:Capture.PNG
Thanks for the renaming tip. Retrying again.
Used the method specified in Article - CS225837 to run the PSI...
Btw, have you installed WC11 on windows 10?
Vincent-Kulak
(To:mkh)
Only on 2012 R2 x64 and Ubuntu 16.04 sorry
imendiola
(To:mkh)
I have installed Windchill 11.1 on Windows 10 with no errors. For previous releases I was using Windows 7...
http://www.prambanan-it.comIker Mendiola - Prambanan IT Services
To install windchill11.0 on windows 10, set following java option.
JAVA_TOOL_OPTIONS => "-Dos.name=Windows 7"
in environment variable => system variable
it worked for me
Thanks & Regards
Saravanan
imendiola
(To:mkh)
Windchill 11.1 is the first release where the installer is able to run in Windows 10. For previous releases you should use Windows 7 for development encironments...
