WIndchill integration with PDMI SAP -> SAP Transfer Workflow template.
VO_10326467
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
We are working on a Windchill integration with PDMI SAP and we are blocked on the step where we have to create or import a SAP Transfer Workflow template.
Can someone support us with this issue?
Here are the errors that I faced
SAP Transfer Workflow template is missing.
Hi @VO_10326467 ,
Please let me know if you are using Enterprise Systems Integration(ESI) module.
The Release to Manufacturing Workflow should be coming Out-Of-The-Box in Enterprise Systems Integration(ESI) module.
If the ESI module is not used then you must check with your deployment builds, this SAP Transfer Workflow Template should be available in your customization deployment script or build in ZIP or JAR file format.
If my response helps, please mark it as the solution to help other members. Thanks for using the Community!
Bhushan Dhamdhere
I would think ESI module would be required to be installed. Do you have this preference at your Site level? ESI - Settings - Workflow - Workflow Template?
This is where the ESI workflow would be configured:
