WT Document Types
GregOlson
WT Document Types
Is there a way to "hide" document types that are not being used to lesson confusion? There are two OOTB types that I would like to disable or hide. They are subtypes of the main document.
In the Type and Attribute Manager select the Document Type and Edit from the Actions Menu. Scroll down in the upper panel and you will see an Instantiable Yes/No Attribute. Select No and Save.
Note - this will propagate to any sub-types so you will need to toggle any sub-types back to "Yes" if you want to use them.
